The EVGA GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal – the most advanced GPU architecture ever created – the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond.
These cards also feature EVGA ACX cooling technology. EVGA ACX once again brings new and exciting features to the award winning EVGA ACX cooling technology. SHP gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more airflow with less power, unlocking additional power for the GPU.
EVGA GeForce GTX 1060 SC
Small Size, Huge Performance
EVGA ACX fans use double ball bearings, which offer 4X longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX and your card will go the distance!
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum “power target” takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
6GB of high performance memory running at extreme Clockspeeds giving you access to higher texture qualities in games and improved 4K gaming performance. Did we mention that this memory is running at an extreme 8,000MHz out of the box??!!
- 1280 CUDA Cores
- Base Clock: 1632 MHz
- Boost Clock: 1860 MHz
- Memory Bit Width: 192 Bit
- Memory Clock: 8008 MHz
- Memory Speed: 0.25 ns
Key Features
- NVIDIA G-SYNC Ready
- OpenGL 4.6 Support
- VR Ready
- NVIDIA® Ansel
- NVIDIA GPU Boost 3.0
- Microsoft DirectX 12 API
- Vulkan API
- PCI Express 3.0
- EVGA ACX 3.0 Cooling
- 1280 CUDA Cores
- Base Clock: 1620 MHz
- Boost Clock: 1847 MHz
Key Features
- VR Ready
- NVIDIA® Ansel
- Vulkan API
- PCI Express 3.0
- 1280 CUDA Cores
- Base Clock: 1607 MHz
- Boost Clock: 1835 MHz
Key Features
- VR Ready
- NVIDIA® Ansel
- Vulkan API
- PCI Express 3.0
- 1280 CUDA Cores
Key Features
- VR Ready
- NVIDIA® Ansel
- Vulkan API
- PCI Express 3.0
- 1280 CUDA Cores
- Base Clock: 1506 MHz
- Boost Clock: 1708 MHz
Key Features
- VR Ready
- NVIDIA® Ansel
- Vulkan API
- PCI Express 3.0
EVGA GeForce GTX 1060 Comparison Chart
