1070
1070
Ultimate Gaming with
EVGA Precision XOC + OC Scanner X
Take on today's most challenging, graphics-intensive games without missing a beat. The EVGA GeForce GTX 1070 Ti delivers the incredible speed and power of NVIDIA Pascal - the most advanced gaming GPU architecture ever created. This is the ultimate gaming platform.
Take your EVGA GeForce GTX 1070 Ti to the next level with exclusive EVGA Precision XOC / EVGA OC Scanner X integration. With the click of one button, EVGA Precision XOC will detect, scan, and apply your optimal overclock!
OC Scanner
Start Scan Save
Player Unknown's Battle Grounds Performance
GTX 1070 Ti Comparison Chart
EVGA GRAPHICS CARD PART NO. MAX POWER LED BIOS COOLER POWER TYPE BACKPLATE
EVGA GeForce GTX 1070 Ti FTW Ultra Silent 08G-P4-6678-KR 235W Yes (WHITE) 2 ACX 3.0 10+2 Yes
EVGA GeForce GTX 1070 Ti FTW2 08G-P4-6775-KR 235W RGB 2 iCX 10+2 Yes
EVGA GeForce GTX 1070 Ti SC HYBRID 08G-P4-5678-KR 217W Yes (WHITE) 1 Hybrid 5+1 Yes
EVGA GeForce GTX 1070 Ti SC Black Edition 08G-P4-5671-KR 217W Yes (WHITE) 1 ACX 3.0 5+1 No
EVGA GeForce GTX 1070 Ti 08G-P4-5670-KR 217W Yes (WHITE) 1 Blower 5+1 No
Available with EVGA iCX Cooling
(Part Number 08G-P4-6775-KR)
EVGA GeForce GTX 1070 With iCX
9 Thermal Sensors
Fan Control
Efficiency
Full Control
Interactive Cooling
Optimized airflow fin design
An optimized air flow design directs air through the fin holes, while half open fins maximize airflow to important components and L-shaped fins increase surface contact.
Interlaced pin fin on Baseplate
Diecast form fitted baseplate and backplate
Backplate makes direct contact with all vital components and new baseplate design with integrated heatpipe significantly reduces component temperatures
Play longer! Overclock Better!
Interaction with Other Devices*
Red Green Blue Red Green Blue
08G-P4-6678-KR
  • CUDA Cores: 2432
  • Base Clock: 1607+ MHz
  • Boost Clock: 1683+ MHz
  • Bus: PCIe 3.0
  • SLI Support: 2-way
  • Type: GDDR5
  • Width: 256 Bit
  • Clock: 8008 MHz
  • Speed: 0.25 ns
  • Bandwidth: 256.3 GB/s
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12 API
  • Vulkan API
  • OpenGL 4.6 Support
  • PCI Express 3.0
  • EVGA ACX 3.0 Cooling
08G-P4-6775-KR
  • CUDA Cores: 2432
  • Bus: PCIe 3.0
  • Type: GDDR5
  • Width: 256 Bit
  • Clock: 8008 MHz
  • Speed: 0.25 ns
Key Features
  • EVGA Double BIOS
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • Adjustable RGB LED
  • Asynchronous Fans
  • 9 additional temp sensors to monitor Memory and VRM
  • GPU / Memory / PWM Thermal Status Indicator LEDs
  • New vented heatsink fin design and pin fins for optimized airflow
  • Safety fuse to protect components from damage due to improper installation or other component failures
  • Redesigned cooling with L-shaped contact fins to improve contact surface area for better heat dissipation
  • EVGA iCX Technology
  • 10+2 Phase Power Design
08G-P4-5678-KR
  • CUDA Cores: 2432
  • Bus: PCIe 3.0
  • Type: GDDR5
  • Width: 256 Bit
  • Clock: 8008 MHz
  • Speed: 0.25 ns
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
  • Hybrid "All-in-One" Watercooler
  • Built in White LEDs
08G-P4-5671-KR
  • CUDA Cores: 2432
  • Bus: PCIe 3.0
  • Type: GDDR5
  • Width: 256 Bit
  • Clock: 8008 MHz
  • Speed: 0.25 ns
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
08G-P4-5670-KR
  • CUDA Cores: 2432
  • Bus: PCIe 3.0
  • Type: GDDR5
  • Width: 256 Bit
  • Clock: 8008 MHz
  • Speed: 0.25 ns
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
* Coming Soon
