EVGA GeForce GTX 1080 FTW2 and SC2
Now Available with 11GHz Memory*
+10% in Total Memory Bandwidth!
EVGA iCX
EVGA iCX Green Blue Green Blue Green Blue
* After firmware update
9 Thermal Sensors
Asynchronous
Fan Control
Asynchronous Fan Control
A New and More
Efficient
Way to Cool
GPU fan determined by GPU temperature (Left Fan)
Power / Memory fan determined by Power / Memory temperature (Right Fan)
Improved Cooling Efficiency
Full Control With
EVGA Precision XOC
Each sensor can be monitored in real time and displayed on PXOC OSD
Control the VGA and Power/Memory fans simultaneously or asynchronously
EVGA Precision XOC
Interactive
Cooling With
Thermal LED Display System
User customized RGB color and visual alarm settings*
PeaceOfMind
Gaming
An EVGA ONLY fuse adds another layer of protection to your card and system.
Optimized Airflow
Fin Design
Fin holes direct airflow through fins
Half open fin maximizes airflow and L-shaped fins increase surface contact
Optimized Airflow Fin Design
Die Cast
Form Fitted Baseplate
And Backplate
Makes direct contact with all vital components.
Interlaced Pin Fin on Baseplate
Play Longer!
Overclock Better!
Interaction with other system devices*
Red Green Blue Red Green Blue
* Coming Soon
EVGA GeForce GTX 1080 with iCX Technology
08G-P4-6686
  • 2560 CUDA Cores
  • Base Clock: 1721 MHz
  • Boost Clock: 1860 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
  • Memory Detail: 8192 MB GDDR5X
  • Memory Bit Width: 256 Bit
  • Memory Clock: 10010 MHz
  • Memory Speed: 0.18 ns
  • Memory Bandwidth: 320 GB/s
Key Features
  • EVGA Double BIOS
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12 API
  • Vulkan API
  • OpenGL 4.6 Support
  • 10 Phase Power Design
  • Adjustable RGB LED
  • Asynchronous Fans
  • 9 additional temp sensors to monitor Memory and VRM
  • GPU / Memory / PWM Thermal Status Indicator LEDs
  • New vented heatsink fin design and pin fins for optimized airflow
  • Safety fuse to protect components from damage due to improper installation or other component failures
  • Redesigned cooling with L-shaped contact fins to improve contact surface area for better heat dissipation
  • EVGA iCX Technology
08G-P4-6583
EVGA GeForce GTX 1080 SC2
  • 2560 CUDA Cores
  • Base Clock: 1708 MHz
  • Boost Clock: 1847 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • Asynchronous Fans
