EVGA Closed Loop CPU Cooler (CLC) 120/240/280
Liquid Cooled Performance
The EVGA CLC 120, 240, and 280 LIQUID CPU Coolers have arrived. These new liquid coolers from EVGA give you incredible performance, low noise, robust software controls and RGB lighting.
Built To
Perform
New cooling block offers improved flowrate and heat transfer surface area for incredible cooling efficiency.
Sync with your
EVGA GeForce GTX
Graphics Card*
Link up your EVGA CLC cooler with select EVGA graphics cards, and match the colors directly from software. One button to control both RGB LED’s! Color profiles even save to firmware.
* Available on select graphics cards.Sleeved
Tubing
Fully sleeved tubing from radiator to CPU block.
New EVGA
Fans
These fans are built for superior cooling and lower noise. The curved housing reduces noise level and unique blade design offers incredible cooling performance. Teflon Nano Bearings ensure a long lifespan.
EVGA Flow Control
Software
This EVGA software gives you full control over your EVGA CLC Liquid Cooler including, fanspeed/curve, RGB lighting, Pump Control, Profiles and more! Also, the fan settings and lighting save to firmware meaning you can set and forget. Now Available. Click Here To Download.
Adjustable
Pump and Fan speed
Set a custom pump and fan speed to fine tune your system for the best performance, or quietest operation possible.
Features
- Built in 280mm radiator and 2x 140mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
- Teflon Nano Bearing in the fans reduce noise and increase lifespan, while the curved housing improves air flow through the radiator to limit vibration and noise.
- Variable controlled fans allow dynamic fan speed based on CPU temperature, and the water cooling efficiency means the fans can operate at a lower speed to reduce noise.
Specs
Waterblock
- Premium Retention parts for Intel LGA2066/2011/2011-v3/1150/1151/1155/1156/1366 and upcoming variants
- AMD retention ring for supporting AM2/AM3/AM4/FM1/FM2/TR4 and upcoming variants
- 100% Copper
- Fully controllable RGB LED
- Noise Level = 20dB(A) (MAX)
Radiator
- 312mm X 139mm X 27mm (LxWxH)
- Aluminum
Fan
- Size: 140 x 140 x 25mm (x2)
- Speed = 600-2200RPM
- Airflow = 113.50 CFM (MAX)
- Static Pressure = 4.20 mmAq (MAX)
- Noise Level = 16.0 dB(A) (MIN) – 39.5 dB(A) (MAX)
- Lifespan = 80,000 Hours
Warranty
- 5-Year Limited Warranty
Features
- Built in 240mm radiator and 2x 120mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
Specs
Waterblock
- 100% Copper
Radiator
- 276mm X 122mm X 28mm (LxWxH)
- Aluminum
Fan
- Size: 120 x 120 x 25mm (x2)
- Speed = 500-2400RPM
- Airflow = 74.82 CFM (MAX)
- Static Pressure = 4.04 mmAq (MAX)
- Noise Level = 16.0 dB(A) (MIN) – 39.9 dB(A) (MAX)
Warranty
Features
- Built in 120mm radiator and 120mm fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customized.
- Teflon Nano Bearing in the fan reduces noise and increase lifespan, while the curved housing improves air flow through the radiator to limit vibration and noise.
- Variable controlled fan allow dynamic fan speed based on CPU temperature, and the water cooling efficiency means the fans can operate at a lower speed to reduce noise.
Specs
Waterblock
- 100% Copper
Radiator
- 156mm X 122mm X 28mm (LxWxH)
- Aluminum
Fan
Warranty
