Back To Top
Built for VR
The EVGA GeForce GTX 980 Ti VR EDITION has arrived. Accelerated by the groundbreaking NVIDIA Maxwell architecture, the GTX 980 Ti delivers an unbeatable 4K and virtual reality experience. With 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, it has the horsepower to drive whatever comes next. And with the VR EDITION, you get an included 5.25” drive bay with front HDMI 2.0 and USB 3.0 giving you easy access to your VR device’s input. The graphics card also has an internal HDMI connector, meaning no external cables will be visible.
Drive Bay
Internal HDMI
Connects to 5.25" Drive Bay, no visible external wires!
ACX 2.0+ Cooling
Remark:
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
*** Versus Reference Fan
Why Double Ball Bearings?
Run Longer, Play Longer with EVGA ACX 2.0+
4x Longer Lifespan
Built With 6GB of High Performance GDDR5 Memory
6GB of High Performance memory running at extreme clockspeeds giving you access to higher texture qualities in games, improved 4K gaming performance and optimized for the next generation of gaming.
06G-P4-3996
EVGA GeForce GTX 980 Ti VR EDITION GAMING ACX 2.0+
Key Features
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenCL Support
  • PCI Express 3.0 x16
  • EVGA ACX 2.0 Cooling
  • dB Inverter
  • Memory MOSFET Cooling Plate
  • Straight Heat Pipes
  • OpenGL 4.6 Support
  • 2816 CUDA Cores
  • Base Clock: 1000 MHz
  • Boost Clock: 1076 MHz
  • Bus: PCIe 3.0
  • Memory Detail: 6144 MB GDDR5
  • Memory Bit Width: 384 Bit
  • Memory Clock: 7010 MHz
  • Memory Speed: 0.28 ns
06G-P4-3998
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
  • 5.25" Drive Bay with Front HDMI 2.0 and USB 3.0
  • 2816 CUDA Cores
  • Bus: PCIe 3.0
EVGA GeForce GTX 980 Ti VR EDITION Comparison Chart
EVGA PrecisionX – Redesigned to harness the power of GPU Boost 2.0, EVGA PrecisionX sets another baseline for what overclocking software should be. Learn more and download it here.
Key Features
  • Temperature Target Control
  • Pixel Clock Overclocking
  • Robust monitoring allowing ingame, system tray and/or Logitech LCD monitoring
  • In game screenshot hotkey, supports BMP, PNG and JPG formats
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 Ti VR EDITION vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
