EVGA PRO SLI BRIDGES V2 Elegant Performance
EVGA has amped up the bling with the EVGA PRO SLI BRIDGE V2. These redesigned bridges come with several improvements over the previous generation SLI bridges. Not only do these new bridges light up and look great on select graphics cards, they also have a high quality aluminum shroud and are optimized for the next generation display resolutions and refresh rates, with a high pixel clock frequency design that gives best compatibility for 120Hz+ and 4K+ gaming!
Gallery
Next Generation Features
- Separate models to support 2-Way (Short), 2-Way (Standard), 3-Way SLI or 4-Way SLI.
- High pixel clock design optimized for 4K+ and 120Hz+ gaming.
- EVGA logo illuminates on select GeForce GTX graphics cards.
- Compatible with all SLI enabled graphics cards.
- Looks super awesome!
Choose the best EVGA SLI Bridge for you
Compatibility
SLI functionality works on all SLI enabled graphics cards. LED functionality works on the following cards:
- All EVGA GTX TITAN graphics cards.
- All EVGA GTX 980 graphics cards.
- Select EVGA GTX 970 graphics cards.
- All EVGA GTX 960 graphics cards.
- All EVGA GTX 780/780 Ti graphics cards.
- Select EVGA GTX 770 graphics cards.
The right fit for your system
